Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Once the hinge guards are removed, lay the laptop flat on its bottom.  Then, lift open the laptop screen as if you were about to use it. With a pair of tweezers, peel off the six rubber cushions from the bezel located around the perimeter of the screen.
  • Once the hinge guards are removed, lay the laptop flat on its bottom. Then, lift open the laptop screen as if you were about to use it.
  • With a pair of tweezers, peel off the six rubber cushions from the bezel located around the perimeter of the screen.
Hier Übersetzung einfügen
