Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Insert a finger nail, or the flat end of a spudger, into the slit between the bezel and the back cover of the laptop. Gently pry the bezel towards you to remove it from the back panel of the laptop.
  • Insert a finger nail, or the flat end of a spudger, into the slit between the bezel and the back cover of the laptop.
  • Gently pry the bezel towards you to remove it from the back panel of the laptop.
  • Hearing a cracking noise is normal. The bezel is not damaged in this process.
  • Continue to pry around the perimeter of the laptop until the entire bezel has been removed.
Hier Übersetzung einfügen
