Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
The screen is attached to the webcam at the top and the inverter at the bottom.  Disconnecting the screen from these two components will give some slack when removing the screen. With a pair of tweezers, grab on to the white connector at the bottom of the screen. Gently, but firmly, pull the connector to the right to to remove it. Repeat this process with the white connector attached to the webcam above the screen.
  • The screen is attached to the webcam at the top and the inverter at the bottom. Disconnecting the screen from these two components will give some slack when removing the screen.
  • With a pair of tweezers, grab on to the white connector at the bottom of the screen. Gently, but firmly, pull the connector to the right to to remove it.
  • Repeat this process with the white connector attached to the webcam above the screen.
Hier Übersetzung einfügen
