Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 8 übersetzen
8. Schritt
Insert the flat end of a spudger into the thin crack running along the side of the laptop.  Gently pry open along the perimeter of the laptop to remove the base. After completely prying the two bases from each other, set the top base flat against the back panel, revealing the circuit board.
  • Insert the flat end of a spudger into the thin crack running along the side of the laptop. Gently pry open along the perimeter of the laptop to remove the base.
  • After completely prying the two bases from each other, set the top base flat against the back panel, revealing the circuit board.
Hier Übersetzung einfügen
