Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
There are three ribbon cable connections that you must disconnect in order to remove the motherboard. The first of these connections is small black - grey plastic connection housing.
  • There are three ribbon cable connections that you must disconnect in order to remove the motherboard.
  • The first of these connections is small black - grey plastic connection housing.
  • Use the plastic opening tool to pull the black part of the ribbon cable housing up and away from the circuit board.
  • Carefully pull the ribbon cable out of the plastic connection housing.
Hier Übersetzung einfügen
