Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Use a plastic opening tool to free the clips on the top and each side of the back cover. The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking. It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
  • Use a plastic opening tool to free the clips on the top and each side of the back cover.
  • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
  • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
  • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
Löse mit einem Plastic Opening Tool die Clips oben und auf jeder Seite der Rückabdeckung.
Das Unterteil ist mit etwas Schaumstoffkleber befestigt. Du solltest das Rückteil mithilfe eines Plektrums vollständig lösen können.
Es ist am Besten nicht um den Sim Slot herum zu hebeln, denn der Kunststoff ist hier sehr dünn und kann beim Hebeln leicht brechen.
[* black] Use a [product|IF145-000|plasticplastic opening tool]tool to free the clips on the top and each side of the back cover.
[* icon_note] The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an [product|IF145-123|opening pick]opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
[* icon_noteicon_caution] It's best to avoid prying around the SIM card slotslot and volume controls, as the plastic herein these areas is very thin and likely to break from prying.
[* icon_reminder] When you ''replace'' the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
