Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
5. Schritt
To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose. Like the keyboard there is one clamp on each side.
  • To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose.
  • Like the keyboard there is one clamp on each side.
  • Grab the cover at the bottom of the screen (near the hinge) and pull outward while leaving the top (near the speaker) connected.
  • Once the bottom is pulled out far enough the top will be able to disconnect as well.
Hier Übersetzung einfügen
