Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Use a #1 Phillips head screwdriver to remove the screws on the RAM's cover panel, as seen in image. Then, use a flat edge tool to pry the cover off, as seen in image. Use your fingers to push the RAM tabs, as seen in image, that secure the RAM outward (away from the RAM). The RAM should then pop up.
  • Use a #1 Phillips head screwdriver to remove the screws on the RAM's cover panel, as seen in image.
  • Then, use a flat edge tool to pry the cover off, as seen in image.
  • Use your fingers to push the RAM tabs, as seen in image, that secure the RAM outward (away from the RAM). The RAM should then pop up.
  • Finally, gently pull the RAM away from the connection. (Repeat this process until all the RAM has been removed from the device).
Hier Übersetzung einfügen
