Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Use a plastic opening tool to flip up the retainer securing the upper component board cable connector to its socket on the logic board. Pull the connector away from its socket on the logic board. Do not lift the cable upward as you disconnect it.
  • Use a plastic opening tool to flip up the retainer securing the upper component board cable connector to its socket on the logic board.
  • Pull the connector away from its socket on the logic board.
  • Do not lift the cable upward as you disconnect it.
Hier Übersetzung einfügen
