Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Using a flat-edge tool begin to pry away the case apart and slowly pulling upward as there is a white ribbon that need to be removed. Make sure to completely untape the largest white ribbon, and let it slide through the top half of the case as you lift it. Make sure to completely untape the largest white ribbon, and let it slide through the top half of the case as you lift it.
  • Using a flat-edge tool begin to pry away the case apart and slowly pulling upward as there is a white ribbon that need to be removed.
  • Make sure to completely untape the largest white ribbon, and let it slide through the top half of the case as you lift it.
Hier Übersetzung einfügen
