Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
  • The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
  • Disconnect the speaker connector from the interface board.
  • Pull the speaker out from the plastic framework.
Hier Übersetzung einfügen
