Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 15 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Flip Bob over and remove the 7 screws around which hold the cover together. Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall. Depending on your model, there may be only 6 screws installed on bObsweep.
  • Flip Bob over and remove the 7 screws around which hold the cover together.
  • Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
  • Depending on your model, there may be only 6 screws installed on bObsweep.
Hier Übersetzung einfügen
