Zum Hauptinhalt wechseln
Englisch
Deutsch
3. Schritt
Gently slide the flat end of a spudger in between the daughterboard cable and the interior midframe to begin to separate the adhesive holding it down. Gently slide the flat end of a spudger in between the daughterboard cable and the interior midframe to begin to separate the adhesive holding it down.
  • Gently slide the flat end of a spudger in between the daughterboard cable and the interior midframe to begin to separate the adhesive holding it down.
Schiebe vorsichtig das flache Ende eines Spudgers zwischen das Kabel der Tochterplatine und den inneren Mittelrahmen, und beginne den Kleber zu lösen, der es befestigt.
