Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 6
Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two. To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
  • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
Hier Übersetzung einfügen
