Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the hard drive screw labeled with a #1 Phillips head screwdriver  as indicated in the picture, then use a flat edge tool to pry the cover off. Use the plastic flap to pull the hard drive out of its slot. Use the plastic flap to pull the hard drive out of its slot.
  • Remove the hard drive screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
  • Use the plastic flap to pull the hard drive out of its slot.
Hier Übersetzung einfügen
