Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 2
Once all the contacts are desoldered, the old joystick can be removed. Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes. Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
  • Once all the contacts are desoldered, the old joystick can be removed.
  • Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes.
  • Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
Wenn viele Lötstellen frei sind kannst du den alten Joystick entfernen.
Achte darauf, dass sämtliche Löcher frei von Lötzinn sind. Du kannst sie gut mit medizinischen Nadeln oder kleinen Bohrern öffnen.
Setze den neuen Joystick in die Platine ein. Achte auf korrekten Sitz und dass die Kontakte sauber in die Löcher passen.
