Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 49 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the following ten screws securing the lower case to the upper case:
  • Two 2.3 mm Pentalobe screws
  • Eight 3.0 mm Pentalobe screws
  • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
Entferne die folgenden zehn Schrauben, die den Boden des Gehäuses befestigen:
Zwei 2,3 mm Pentalobe Schrauben
Acht 3,0 Pentalobe Schrauben
[* black] Remove the following ten screws securing the lower case to the upper case:
[* red] Two 2.3 mm Pentalobe screws
[* orange] Eight 3.0 mm Pentalobe screws
[* icon_reminder] Throughout this repair, [product|IF145-167-4|keep track of each screw|new_window=true] and make sure it goes back exactly where it came from to avoid damaging your device.
