Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side, to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • If you're replacing the display with a new one, you may need to transfer some components from the old display to the new display.
  • During reassembly, head over to our display adhesive guide to install the new adhesive.
Hebe das Display nach oben aus dem Rahmen und entferne es aus dem iMac.
Möglicherweise musst du an einer Seite anfangen, das Display anzuheben, um den Rest des Klebebandes zu lösen.
Sei vorsichtig bei der Handhabung des Display. Es ist groß, schwer und aus Glas.
[* black] Lift the display up from the frame and remove it from the iMac.
[* black] It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass.
[* icon_reminder] If you're replacing the display with a new one, you may need to transfer some components from the old display to the new display.
[* icon_reminder] During reassembly, head over to our [guide|137411|display adhesive guide] to install the new adhesive.
