Englisch
Deutsch
10. Schritt
Using a spudger very carefully lift the black lock on the connector Gently pull the cable out of the connector
  • Using a spudger very carefully lift the black lock on the connector
  • Gently pull the cable out of the connector
  • Using a pick very carefully separate the touchscreen cable from the display
  • The chip on the cable at that point is glued to the display but can be easily separated by sliding a pick under it
  • If it is not separating with ease place the iOpener on top this should loosen the adhesive.
Hier Übersetzung einfügen
