Englisch
Deutsch
12. Schritt
Finally to tidy up the case The adhesive strip (double sided tape) used to attach the old display probably did not come off with the display Use the iOpener to loosen the adhesive
  • Finally to tidy up the case
  • The adhesive strip (double sided tape) used to attach the old display probably did not come off with the display
  • Use the iOpener to loosen the adhesive
  • Use the picks to lift up the edges and then peel the strip off the case
  • This may again take several attempts with heating and picking, be patient, the slower you go the larger the strip you should be able to lift which should make it easier to take the whole thing off in one (or 3) goes
Hier Übersetzung einfügen
