Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Do not pull the coil ring as the wire will break away from the the circuit board With flat screw driver, slide down along the case. Gently push both plastic tab toward the center
  • Do not pull the coil ring as the wire will break away from the the circuit board
  • With flat screw driver, slide down along the case. Gently push both plastic tab toward the center
  • To help you removing the inner part, you can insert another screw driver here and pull gently toward you while you try to free the plastic tab
Hier Übersetzung einfügen
