Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw above the hook for the hand strap.
  • Rotate the camcorder so that the tape compartment is facing you.
  • Remove the single 4.5mm black screw above the hook for the hand strap.
  • Undoing the strap on one end may help.
  • Rotate the camcorder so that the lens is facing you.
  • Remove the single 4.5mm black screw from the front panel.
Hier Übersetzung einfügen
