Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
8. Schritt
Very carefully remove the front cover from the main body of the camcorder. This should come apart with relative ease, however a plastic opening tool may help you remove this panel a little more easily.
  • Very carefully remove the front cover from the main body of the camcorder.
  • This should come apart with relative ease, however a plastic opening tool may help you remove this panel a little more easily.
  • There is a ribbon cable attached to the front panel and the camcorder body, so be careful not to pull that off when you remove this panel.
Hier Übersetzung einfügen
