Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
5. Schritt
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw above the hook for the hand strap.
  • Rotate the camcorder so that the tape compartment is facing you.
  • Remove the single 4.5mm black screw above the hook for the hand strap.
  • Undoing the strap on one end may help.
  • Rotate the camcorder so that the lens is facing you.
  • Remove the single 4.5mm black screw from the front panel.
Hier Übersetzung einfügen
