Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 23 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
If you don't have an iSclack, use a single suction cup to lift the front panel:
Manual Opening Procedure
  • If you don't have an iSclack, use a single suction cup to lift the front panel:
  • Press a suction cup onto the screen, just above the home button.
  • Be sure the cup is pressed securely onto the screen to get a tight seal.
  • If the screen is completely shattered to the point that a suction cup will not stick, use clear packing tape or similar to cover the screen. Sometimes you can even pull up using just the tape without using the suction cup.
Wenn du keinen iSclack zur Verfügung hast, verwende einen Saugnapf, um die Display Einheit anzuheben:
Presse den Saugnapf über dem Home Button gegen das Display.
Überprüfe, ob der Saugnapf auch wirklich richtig sitzt.
[title] Manual Opening Procedure
[* black] If you don't have an iSclack, use a single suction cup to lift the front panel:
[* black] Press a suction cup onto the screen, just above the home button.
[* icon_note] Be sure the cup is pressed securely onto the screen to get a tight seal.
[* icon_note] If the screen is completely shattered to the point that a suction cup will not stick, use clear packing tape or similar to cover the screen. Sometimes you can even pull up using just the tape without using the suction cup.
