Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 24 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
6. Schritt
Peel up the two pieces of foil tape on the left side of the keyboard area.
  • Peel up the two pieces of foil tape on the left side of the keyboard area.
  • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
  • Carefully disconnect the microphone and power cables from the logic board. Using your fingernails or a dental pick, carefully pry the connectors from their sockets. Make sure you're pulling only on the connector and not on the socket.
Hier Übersetzung einfügen
