Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 16 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Peeling up yellow tape as necessary, remove the following 8 screws:
  • Peeling up yellow tape as necessary, remove the following 8 screws:
  • One 4.5 mm Phillips on the right side of the heat sink.
  • Three 6 mm Phillips near the display.
  • Two large 7.5 mm Phillips with springs (don't forget to remove the springs). If the springs are not releasing, needle nose pliers can help get this done.
  • Two 13 mm screws from the left side of the heat sink and the right side of the fan.
Hier Übersetzung einfügen
