Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 8 übersetzen
Schritt 8
Fire HD 6 Repairability Score: 8 out of 10 (10 is easiest to repair). The rear case is very easy to open, granting trouble-free access to the internals.
  • Fire HD 6 Repairability Score: 8 out of 10 (10 is easiest to repair).
  • The rear case is very easy to open, granting trouble-free access to the internals.
  • All the fasteners found inside are T5 Torx screws—one non-proprietary screwdriver is all you need.
  • Simplistic design and limited functionality means fewer components and less headache for disassembly.
  • Battery adhesive is much stronger than necessary, which makes disassembly hazardous.
  • The glass panel is fused to the front plastic frame, meaning a heat gun is required for replacing cracked glass (or you have to replace both components together).
  • Lack of available replacement parts has limited repair options in other Kindle models. We can only hope this model doesn't share the same fate.
Hier Übersetzung einfügen
