Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Slowly work your way across the lower edge of the front display bezel until it is free from the display assembly.
  • Slowly work your way across the lower edge of the front display bezel until it is free from the display assembly.
  • Be sure to pry up as far away from the LCD as possible, as it extends below the edge of the front display bezel.
  • When you get about half way across, pry up from the other side of the front display bezel's lower edge to ease the process.
  • Remove the front display bezel from the display assembly.
  • To help the adhesive avoid losing is tackiness, do not excessively handle the adhesive and be sure to keep it clean until you are ready for installation.
Hier Übersetzung einfügen
