Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Gently pry up the connectors there is one per speaker Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the  connector and the board to lift the connector away from the board. Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the  connector and the board to lift the connector away from the board.
  • Gently pry up the connectors there is one per speaker
  • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
Hier Übersetzung einfügen
