Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already. Wiggle the front cover out from under the white piece and lift up from the gun. Pulling the cover off is tricky due to its inner fitting.
Removing the front cover
  • An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already.
  • Wiggle the front cover out from under the white piece and lift up from the gun.
  • Pulling the cover off is tricky due to its inner fitting.
  • Be sure to replace the orange block, spring, and clip before this step in reassembly.
Hier Übersetzung einfügen
