Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the twelve #00 1 cm Phillips screws. Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
Removing the outer screws
  • Remove the twelve #00 1 cm Phillips screws.
  • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
  • Rotate the gun so that the front is facing you to remove the final screw.
Hier Übersetzung einfügen
