Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 4 übersetzen
Step 4
Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body. Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack. Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
Remove the Pickguard
  • Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body.
  • Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
Hier Übersetzung einfügen
