Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
TarDisk Teardown is similar to Nifty TearDown. The sonic weld is on the front edges of the card. Work a razor blade or Xacto knife along the weld from cap to MicroSD port opening. Next Run blade along top weld and right side. Last run blade down between the front and back plastic to break weld at bottom that holds end-cap in place. End-cap pops out of mold same as Nifty. Adapter Chip should lift easily out of its mold with little resistance.
Opening TarDisk MiniDrive
  • TarDisk Teardown is similar to Nifty TearDown. The sonic weld is on the front edges of the card. Work a razor blade or Xacto knife along the weld from cap to MicroSD port opening.
  • Next Run blade along top weld and right side. Last run blade down between the front and back plastic to break weld at bottom that holds end-cap in place.
  • End-cap pops out of mold same as Nifty. Adapter Chip should lift easily out of its mold with little resistance.
  • Now the card is completely torn down into 4 parts
  • *Front Plastic Mold, *Rear Plastic Mold, *End-Cap *Adapter Chip
Hier Übersetzung einfügen
