Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
After the battery has been removed, use the spudger to disconnect the remaining ribbons. Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment. Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment.
Removal of Ribbons
  • After the battery has been removed, use the spudger to disconnect the remaining ribbons.
  • Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment.
Nachdem der Akku entfernt ist, kannst du mit einem Spudger die restlichen Flachbandkabel lösen.
Achte darauf, dass sich je ein Kabel auf jeder Seite (Lautstärkeregelung, Einschalttaste) und oben befindet. Sie formen das Akkufach.
[title] Removal of Ribbons
[* black] After the battery has been removed, use the spudger to disconnect the remaining ribbons.
[* red] Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those formfrom the battery compartment.
