Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo. Pry up the rear inner frame along the right edge using the method described in previous steps. Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
  • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
  • Pry up the rear inner frame along the right edge using the method described in previous steps.
  • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
Hier Übersetzung einfügen
