Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Step 4
To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable. Pull the ribbon cable to remove it from the connector. Repeat the exact steps above for the other ribbon cable.
Detaching keyboard Ribbon Cables
  • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
  • Pull the ribbon cable to remove it from the connector.
  • Repeat the exact steps above for the other ribbon cable.
  • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
Hier Übersetzung einfügen
