Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar. If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier. If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Remove the Strings from the Bridge
  • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
  • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Hier Übersetzung einfügen
