Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 9 übersetzen
9. Schritt
Lift the front panel out of the inner case, minding the cable still routed through the bottom of the Evo. Carefully de-route the front panel ribbon cable through the slot in the inner case.
  • Lift the front panel out of the inner case, minding the cable still routed through the bottom of the Evo.
  • Carefully de-route the front panel ribbon cable through the slot in the inner case.
  • Remove the front panel.
  • Notice the four (4) clear plastic hooks that are adhered behind the menu buttons. Look closely. Each one is shaped differently and in a particular orientation.
  • If the replacement front panel does not have these installed already, carefully remove and transfer them from the old panel to the replacement.
Hier Übersetzung einfügen
