Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove the glass container and place the blender upside down on a solid surface. Remove the four rubber feet using the needle nose pliers. Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
Removing the Back Panel Part 1
  • Remove the glass container and place the blender upside down on a solid surface.
  • Remove the four rubber feet using the needle nose pliers.
  • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
Hier Übersetzung einfügen
