Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Use the plastic opening tool to take out the inner back cover after all the screws have been removed. This will expose the motherboard and the attached battery. Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
The Inside of your Phone
  • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
  • This will expose the motherboard and the attached battery.
  • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
Nachdem die Schrauben entfernt sind kannst du mit dem Plastikhebel den inneren Deckel ablösen.
Nun liegt die Hauptplatine und der Akku frei.
Achte auf die beiden Knöpfe an der Seite, die nun leicht herausfallen können.
[title] The Inside of your Phone
[* black] Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
[* black] This will expose the motherboard and the attached battery.
[* black] Take note that once the inner back cover is removed the twovolume and power buttons on the side can easily fall out or be removed.
