Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Remove the five screws at the top of the panel using a Phillips head screwdriver. Two 2.05mm Philips head screws
Remove the top plastic panel
  • Remove the five screws at the top of the panel using a Phillips head screwdriver.
    • Two 2.05mm Philips head screws
    • Three 2.44mm Philips head screws
    • Also remove the screws with the warranty stickers.
  • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
  • Once you have disassembled your device, your warranty will no longer be valid.
Hier Übersetzung einfügen
