Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 5
Disconnect one by one: the Touchscreen flex cable the Volume buttons & Mic flex cable
  • Disconnect one by one:
  • the Touchscreen flex cable
  • the Volume buttons & Mic flex cable
  • the Dock connector flex cable
  • Carefully insert a plastic tool under the battery to pry it up from the adhesive. Avoid bending the battery.
  • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
  • Now you can separate the Dock flex cable.
Trenne nacheinander:
das Touchscreen Flexkabel
das Lautstärkeregler & Mikrofon Flexkabel
das Dock-Anschluss Flexkabel
Verwende ein Plastic Opening Tool, um den Akku vom Kleber zu lösen.
Achte auf die Flexkabel, die sich unter dem Akku befinden. Auf dem letzten Bild in diesem Schritt siehst du die Kabel und wo sich der Klebestreifen befindet.
Nun lässt sich das Dock Flexkabel lösen.
[* black] Disconnect one by one:
[* red] the Touchscreen flex cable
[* greenorange] the Volume buttons & Mic flex cable
[* yellow] the Dock connector flex cable
[* blue] Useblack] Carefully insert a plastic tool under the battery to unstickpry it up from the adhesive. Avoid bending the battery.
[* icon_caution] Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
[* black] Now you can separate the Dock flex cable.
