Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
For enough clearance to remove the hard drive, the logic board must be slightly removed. To accomplish this, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may severely damage the logic board. Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
  • For enough clearance to remove the hard drive, the logic board must be slightly removed. To accomplish this, two cylindrical rods must be inserted into the holes highlighted in red.
  • Inserting instruments into any logic board holes other than the ones highlighted in red may severely damage the logic board.
  • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
  • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
  • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
  • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
Um genug Freiraum für das Entfernen der Festplatte zu haben, muss das Logic Board ein Stück weit verschoben werden. Dazu müsste zwei zylindrische Stäbchen in die rot markierten Löcher eingesetzt werden.
Wenn du irgendwelche Instrumente in andere Löcher als die beiden rot markierten einsetzt, kannst du das Logic Board stark beschädigen.
Setze das Mac Mini Logic Board Removal Tool in die beiden rot markierten Löcher ein. Schiebe es durch, bis es das äußere Gehäuse unter dem Logic Board berührt, das ist wichtig, bevor du weitermachst.
Wenn du kein solches Werkzeug hast kannst du probieren zwei 2,5 mm Stifte in die Löcher einzuführen.
Ziehe das Werkzeug vorsichtig in Richtung der I/O Platine. Diese Platine und das Logic Board sollten etwas aus dem äußeren Gehäuse rutschen.
Höre auf zu hebeln, sobald die I/O Platine sichtbar vom Gehäuse getrennt ist. Entferne das Removal Tool.
[* icon_note] For enough clearance to remove the hard drive, the logic board must be slightly removed. To accomplish this, two cylindrical rods must be inserted into the holes highlighted in red.
[* icon_caution] Inserting instruments into any logic board holes other than the ones highlighted in red may severely damage the logic board.
[* black] Insert a Mac Minimini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
[* icon_note] If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
[* black] Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
[* black] Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac Minimini Logic Board Removal tool.
