Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Englisch
Deutsch
Schritt 8
Remove the vibrator by lifting it up with a plastic tool. It is only attached with double-sided tape. Remove the screw hidden between the jack and upper screen ribbon. This holds the proximity sensor and jack ribbon. That you can take gently away (don't break it). Take the speaker out. This is easy.
Finishing the Upper Screen Frame parts.
  • Remove the vibrator by lifting it up with a plastic tool. It is only attached with double-sided tape.
  • Remove the screw hidden between the jack and upper screen ribbon. This holds the proximity sensor and jack ribbon. That you can take gently away (don't break it).
  • Take the speaker out. This is easy.
Hier Übersetzung einfügen
