Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
To remove the ribbon cable, use the spudger to lift each side of the connector from the socket. Gently pull up on the connector to completely remove the connector from the socket. Remove front panel from the motherboard.
Detaching Ribbon Cable
  • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
  • Gently pull up on the connector to completely remove the connector from the socket.
  • Remove front panel from the motherboard.
Hier Übersetzung einfügen
