Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 9 übersetzen
Schritt 9
De-route the digitizer and LCD cables through the steel inner frame, and remove the display from the iPhone. When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable. When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
  • De-route the digitizer and LCD cables through the steel inner frame, and remove the display from the iPhone.
  • When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable.
  • When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
  • If the digitizer cable has not been installed correctly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
  • During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
Führe das Digitizer- und das LCD-Kabel durch den inneren Stahlrahmen und entferne das Display vom iPhone.
Wenn du das Display wieder installierst, glätte vorsichtig das Digitizer- und das LCD Datenkabel und führe sie durch den Slot im Stahlrahmen. Dieses Foto zeigt ein nicht korrekt installiertes Display mit einem Knick im Digitizerkabel.
Wenn das Front Panel korrekt installiert ist, sollten LCD und Digitizer Kabel direkt nebeneinander sitzen und gleich lang sein (so wie im zweiten Foto).
Wenn das Digitizer Kabel nicht korrekt installiert ist, reicht es nicht bis zur Buchse auf dem Logic Board. Versuche nicht, es mit Gewalt langzuziehen, sonst reißt es. Entferne die Display Einheit, glätte das Kabel und führe es ganz durch, wie gezeigt.
Berühre während dem Wiederzusammenbau nicht den metallenen Bereich unten am LCD Datenkabel, da dies Probleme mit dem LCD verursachen kann. Wenn du es versehentlich berührst, reinige es vorsichtig mit einem Tupfer Alkohol, bevor du weitermachst.
