Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
The rubber membrane surrounding the home button is very thin and tears easily. Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
  • The rubber membrane surrounding the home button is very thin and tears easily.
  • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
  • Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
  • Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
Drücke vorsichtig die linke obere Ecke des Home Buttons hoch, weg vom Display.
Drücke den Home Button nicht komplett durch - du musst nur eine Ecke freilegen, damit du den Button mit einem Spudger heraushebeln kannst.
Der Membranring ist sehr dünn. Wenn du glaubst, du zerreißt den Button, erwärme ihn leicht (mit einem Haartrockner, iOpener oder einer Heißluftpistole) und versuche es erneut.
[* icon_caution] The rubber membrane surrounding the home button is very thin and tears easily.
black] Gently pushApply mild heat (with an [product|IF145-198-2|iOpener], heat gun, or hair dryer) to soften the top left corner ofadhesive securing the home button up awaymembrane.
[* black] Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate
[* icon_caution] Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
[* icon_note] This membrane is very thin. If you feel like you're going to tear the button, apply mild heat (with an [product|IF145-198-2|iOpener], heat gun, or hair dryer) and try again.
