Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 17 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 2
Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
  • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
  • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
Hebe die Ausbuchtung am Lüfter, der dem RAM am nächsten ist, aus dem Abstandshalter am hinteren Gehäuse.
[* black] Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
[* icon_note] If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
