Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 23 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6
Remove the following Phillips screws from the battery connector bracket:
Removing the battery connector bracket screws
  • Remove the following Phillips screws from the battery connector bracket:
  • One 2.2 mm screw
  • One 3.2 mm screw
  • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
Entferne die folgenden Kreuzschlitz Schrauben von der Abdeckung des Akkuanschlusses:
Eine 2,2 mm Schraube
Eine 3,2 mm Schraube
[title] Removing the battery connector bracket screws
[* black] Remove the following Phillips screws from the battery connector bracket:
[* red] One 2.2 mm screw
[* orange] One 3.2 mm screw
[* icon_note] During your repair, [product|IF145-167-4|keep track of each screw|new_window=true] and make sure it goes back exactly where it came from to avoid damaging your phone.
